Dimention for angled walls
I would like add dimensions both for the core centerline and finish face: exterior on angled wall.
For now I have to add an extra detail line to pick up these edges.
2 Comments
dplumb_BWBR
I suspect this wouldn't work for the Code Centerline, but you can get to the Exterior Face by using the TAB key.
It's subtle because it only shows a dot, but you can get to the point where the exterior lines intersect.
It's also slightly more visible if you do NOT have Thin Lines turned on.
ysautodesklover
Hi dplumb,
Thank you for your comment.
Yes, I could add the dimension for the exterior wall and I created the way to add the core center line with the temporary dimension by steps: the first and second pictures.However, problem occurs when the compound wall has finishes on the only one side.The dimension become off actual center line: the third picture.
Forma Design Contest
Technology Administrators
