Dimensions position in break section
If you dimension in a view and break the view, there is no way to move around the dimension after.
We have to position the dimension before breaking the view and that is annoying.
Thank you for the consideration
10 Comments
lionel.kai
View breaks tend to have odd behavior in general. When placing Revision Clouds across boundaries you have to break them as well.
roldham89U5G
View breaks in detail callout views can be quite hit & miss when you have dimensions displaying across the split view. This makes dimensions hard to move or select.
Tags (4)
similar/included ideas:
other ideas related to View Breaks:
other ideas related to View Breaks (fixes):
and new features:
mike4D3HJ
This may just be a bug (2020.2.6), but having the ability to modify a dimension which is spanning across view breaks would be helpful and quite necessary with enlarged detail views.
This sounds a lot like a bug, I think it should be fixed in a future version
Mark_Engwirda
Yes, it is very annoying...
Use an Ordinate dimension type.
Mark_Engwirda
Thanks, I just tried general as well and it works fine too.
Maybe I should have double-checked this first 🙂
