We could use an easier way to delete views when working in a sheet. I would like to see a confirmation dialog (that you could disable) which asks if you would like to delete the view permanently or just delete the view from the sheet, whenever you delete a view. Alternatively, it could be a separate right-click option for views.
I have sheets full of common notes and details (all are either detail or legend views) which I use on nearly every project. These are stored in their own project files. I would like to be able to load the details views into my project, in bulk, on sheets, then delete the detail views I don't need. The alternative is loading the details in one at a time and manually dragging each one back onto its respective sheet. (Yes, I realize this method reduces the likelihood that I bring unneeded line patterns, materials, etc into my project, but the time cost is quite high for a small savings in file size, and the extra items can be purged out later.)
