Cut linked 3D DWGs
Cut linked 3D DWGs
Let a section be able to cut 3D DWGs. I know there are workarounds but those are not ideal.
6 Comments
Viveka_CD
Autodesk Support
Please see article: 3D DWG or SAT is not being cut in section or elevation in Revit
The article mentions a couple of workarounds in AutoCAD and Navisworks, where the 3D dwg can be brought inside Revit as a coordination model.
coneil5
The coordination model .NWD method mentioned in the article does not allow dimensioning in Revit. Not a great work around. We're trying to use sub contractor .DWGs to coordinate horizontal penetration drawings. We're using all Autodesk products, this should not be that difficult, would love to see it improved.
It is very common for 3D pipe geometry to be shown in section, for example:
  • civil services - including sewers and underground utilities such as water and gas pipes
  • building services - incuding pipes and drains
I echo @coneil5 who mentions the need to dimension sub-contractor DWG's in Revit
Effective sectioning of Civil 3D, Plant 3D and DWG geometry in Revit has been a significant prodictivity drag on very large construction projects including Hospitals, Hyperscale Data Centres and complex Pharma manufacturing projects that I have been involved in.
This is a great opportunity for Autodesk or a third party developer, to address a real pain point with architects, engineers, constructors and project owners so that Revit can product legible and dimensionable sections of pipes.
Thanks.
Key to examples:
A - Plant 3D Geometry in Revit (pipe vectors only showing)
B - modified geometry (good example)
C - Civil 3D water pipes in Revit (approximated circles - poor resolution)
D - Mechanical pipes rendering well in Revit
joslindave
Yes, this is long overdue. Need to be able to have 3D cad geometry cut in plans, sections, elevations, etc. by the view extents/range, just like we all expect.
michael-coffey
The strange thing is that you can do this in a 3D view with the section box, but floor plans, elevations, sections, etc don't respect the cut plane.
kimberly.fuhrman
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
Forma Design Contest
