Create Pipe without fittings options
Using flexible pipes to model pipe networks that are made of them demands a lot of time, and we can´t control the bend radius.
My suggestion it to create a solution, similar to conduit without fittings, which is very easy to route and control the minimun bend radius.
21 Comments
wr.marshall
IF Google Translate, translated  correctly your idea is for flexible pipe.
Translation:
good morning, it would be very useful to have the command to insert an electric hose
Nowadays, the insertion of flexible PVC pipes in the outlet of elements such as lamps, electrical panel outlets, among other things, is widely used in construction.
It is necessary to calculate these sections of pipe which all in all make up a quantity to keep in mind
See this idea: Create Pipe without fittings options - Autodesk Community
@kimberly_fuhrman-jones please combine
