Create Ceilings via Dynamo or API
We need to be able to create ceilings programmatically - whether using Dynamo or the API. Ideally we would be able to create a ceiling object whose sketch is based on the boundary of a Room. Using Dynamo we can already create floors based on the geometry of the Room. But the API does not provide a way to create new ceilings. This would really help improve our BIM workflow.
32 Comments
Yes,
For now I am going to model roofs as ceilings, floors as roofs, butter my toast inverted.
thanx,
doctor phostle
Any updates on this?
Let’s make this happen ADSK
A feature that should already exist really. Autodesk, we have floor, roof and ceiling by footprint already, can't we just make this work on Dynamo?
Just get it done Autodesk, stop making my life a pain in the ass.
e_juma
Really want this be supported in API. Can you do it, Autodesk friends?
It will be very useful to have this API, thanks
I would really appreciate this implementation! Frees up so many workflows. You guys can do it!!
2 Years and nothing happened
crthomas
Yep. I guess they're done making Revit better.
panasitiB8QEQ
gregoriosaura
KalvinC
I can do this with floors why would I not be able to do this with ceilings?
Please implement this ASAP. Thank you ADSK!
Can we get this pushed out from the API please? We have hundreds of applications that require this immediately for Mechanical, Electrical and Architectural. Thank you.
@crthomas  Workarounds....Always workarounds...But if you want ceilings to show with a thickness, material, etc and have it linked to parameters for scheduling, then this is it! Directshapes. They are a bit permanent, but it is a very fast way to create hundreds/thousands of ceilings in your project using a program or database related to room data. 🙂
yes, would be good to have to stop manual creation the auto-ceiling commands dont work
peterkamal91
Yeah, it is very important and will  save a lot of time, I hope to see this feature soon
not that autodesk ever cared about what their customers want in a product, but +1 for a usable solution......
Jensm_BIG
I asked them the question at the last EU BiLT conference in Edinburgh, and the official answer was that apparently the code behind ceilings is too old to support the API, as the API was written into Revit after the code was created for ceilings. They will be looking into it, but I'm just amazed how that can possibly be the answer, I mean how many programmers do they need to rewrite the code for ceilings?! If they need 20 then hire 20... for the prices we pay for Revit it should be peanuts...
