Conditional formatting in Schedules
Using conditional formatting in schedules is limited.
More filter options would give a lot of freedom and opportunities to do more with schedules.
  • Possibility to select “family” or “type” from Fields.
  • Add more options to filter value -> e.g: contains, does not contain, starts with, ends with, etc.
Now only “Equal and Not equal to” are available to filter value.
Filter options as provided in view filters would be a big improvement for conditional formatting in schedules.
22 Comments
samuelsanf
I would like to see that conditional formatting change the text, not only the cell background.
pascal.robben
That would also be a nice additional option indeed
Magnus.B
I agree, the conditional formating is way to limited, and/or filter and contains/does not contain would be a good start. Text, fontsize etc could follow.
EddieSaez
OH how I wished this was available right now in 2019
kboschJGDNZ
"I would like to see that conditional formatting change the text, not only the cell background."
This idea would be great as you can hide certain values that you don't want to see in your schedule by making the text white.
Another good idea
C2V-SM
Wanted to filter a view list by View Name and we are limited to only 2 choices: "equal to" and "not equal to".
Who the hell is ever gonna filter for a single View Name...
plz add "Begin with", "Contain", etc.
@C2V-SM
Are you talking about Filter or Conditional Formatting?
C2V-SM
@ToanDN
Hi, sorry I have to be more careful with words...  😉
I was thinking FORMATING filters; we also have similar issues in Browser Filtering making View Name option completly useless...
pascal.robben
3 years later... what's the status on this frequently asked topic?
Filter options overall could be more efficient.
C2V-SM
@pascal.robben
Yeah, agree! We'll have to rely on add-ins or code it our self i guess... 😉
pascal.robben
@C2V-SM:
Do you have a brilliant add in? 🤔
C2V-SM
@pascal.robben
Nothing yet that I know about to enchance built-in schedule capabilities.
For now the only way I know for fromatting would be to export to excel and link back as a drafting view... using something like RushForth, Ideate Software, etc.
Arciviz
Only one Conditional formatting is possible in Schedules.
Unable to add more Conditional formatting is possible in Schedules.
https://prnt.sc/VBiX5AqkWEji
aaugustineF6WQR
Currently, the conditional formatting within schedules can highlight cells where a value exceeds a static numerical value.
My idea would expand upon that, allowing the comparison between the values of two different fields.
For example: It would be fantastic for HVAC design, to be able to highlight within a schedules, any Zones where the Specified Supply Airflow is less than the Calculated supply Airflow, or where the actual Supply airflow is less than the specified Supply Airflow.
Currently, this is not possible without external resources, or creating custom calculated parameters.
Tags (3)
Mike.FORM
This is possible using a calculated parameter and conditional fomulas.
Create a calculated parameter name "Airflow Check" specified as an 'Integer' and then use the formula if(Specified Supply Airflow < Calculated supply Airflow, 1, 0)
Then for the parameters you want to get highlighted add a conditional formula checking if the "Airflow Check" = 1.
You can then also make the calculated parameter a hidden field so it does not show in the schedule.
birhanzl
Dear autodesk,
please add new formating filter like max, min, larger, smaler,... and add a buton for option "apply to the whole line".
Thanks a lot
Tags (1)
Anna_Pawlewska_TFK
We still need this feature! Beyond what has been described above, we are looking for the ability to apply multiple conditions to the same column in schedules. While we know there is a calculated formula option, having this feature would significantly improve the time spent on schedules in Revit.
Mike.FORM
It would also be nice to just have the check for has value/has no value so that we can highlight cells that haven't been filled out.
Sometimes when you have large schedules it can be difficult to notice the single cells spread throughout that do not have a value.
pascal.robben
‎Started this topic on 04-12-2018. Don't know if it matters at this point to keep on posting?
Also on other topics the same story
