Combined length of selected Pipes
I often quickly need the Lenght of a Pipe-Run as an MEP-Engineer. A Pipe-Run may consist of a couple of Bows and Pipes. A quick way would be to select the Pipe-Run with "Tab" as it is now, and then in the Properties-Window see the combined Length of the Pipe-Run, along with Pipe-Size, Number of Bows and sow on. An ability to customies this "Combined-Category-Properties-Window" would be nice.
Attached an example of a Pipe-Run. This ability should apply to all types of View (3D, Plan, Section… etc.)
1 Comment
erin.card
Yes please!  I design tiny houses and we have maximum-pipe lengths (that are not very long) between fixtures or vents and it would be great to double check to make sure I'm within code on those or need to move a vent.
Forma Design Contest
Technology Administrators
