COBie addin to support processing of pre-selected eleements
It would be great if the COBie Addin "Modify > Bath Modify" tool could work on pre-selected elements rather than just via the current selection tree, e.g. select some elements, run the tool, only those elements are processed.
The reason for this is that it's often the case that you run the tool, find that an element couldn't report the space it was in, fix that, and then have to run the tool on broad categories again which takes too long.
