In section or elevation views there is a link on your level bubbles that takes you to the associated floor plan. It does not appear that you can change which view it is linked to. It would be super nice if you could control what view is set as the default for that link. This is an issue if you have duplicated the original view many times and that original view is not used on a sheet. When you print a PDF set, the hyperlink generated from your levels will not work.
