Calculated value in Color Fill Legends
We recently got Calculated values in Tags.
I would like to be able to do a Calculated value in a Color Fill Legend.
As an example, I would be able to color rooms that have, "(Actual Airflow / Specified Airflow) < 1" Red.
4 Comments
Magnus.B
Yes, Love the Idea!
In a similar vein, it would be great if Color Fills could actually relate to the model better. So for example, if you could assign a color to a particular room parameter, and have it be consistent across multiple color fill schemes, it would make the Color Fills much more useful!
bvirglSB7SX
Observer
This would be a much desired feature.
Evan.S.Hall
Yes please. It would also be nice to be able to include combination fields.
I know I can kind of do this in schedule, or it can be done if we create a new shared parameter and fill out the value manually or with Dynamo, but these options are not as useful or robust. Some fields that would be nice to visualize:
Specified Supply Air/Square foot
(nearly anything quantifiable)/Square foot
Net airflow into/out of a space
A combination of temperature set point values (min - max)
A combination of a few different space classification data
These are mostly HVAC examples, but I'm positive there are some creative users from other disciplines that could make use of such a feature.
Also note that this has come up on other forums:
https://forums.autodesk.com/t5/revit-mep-forum/color-fill-schemes/td-p/3456746
https://www.revitforum.org/forum/revit-all-flavors/wish-lists-feature-requests/-2011-archive/3583-
@Ricard_S, thanks for the original post. Are you able to edit the subject to include the phrase "color scheme"? That might help attract more traffic.
Forma Design Contest
