Better Topography tools
It'd be great to have some more options when it comes to topography
  • Drawing a floor in plan view, using the pick lines tool should be able to grab a contour edge.
  • Clearer method of establishing 'boundary' and 'interior' points.. currently if you accidentally delete a boundary point, it'll delete every point that is outside the new boundary.
  • better, bi-directional association with Infraworks.
    • should be able to select a region of Infraworks and have that associated as the 'site' in the revit model.
1 Comment
lionel.kai
We should be able to switch points between "boundary" and "interior"... Current process involves using Split Surface to get rid of the automatically-generated junk around the edges...
Just curious - why would you need to select a contour edge for a Floor? Is it part of a workaround for something else? or you're pouring a lanai slab up to existing conditions instead of a clean/straight edge?
Related idea:
https://forums.autodesk.com/t5/revit-ideas/solid-mesh-topography-with-boolean-operations/idi-p/67037...
