I would like to be able to see what the current work plan is and be able to change it using a drop-down menu directly on the user interface....
Please see the image below as to where the drop-down might go....
This will save you having to use the set tool and its submenu or the use of shortcut keys to know what your current work plane is set to... or if you want to change it.
