Area Schedule Columns vs Rows
This is both a request and a plea. It would be ENORMOUSLY helpful if there was a way to assign parameters in area schedules to be columns or rows. We constantly need to create scheudles that describe the inclusions and exclsuions of floor areas by level and there is no way to set the various uses in vertical columns and use a calculated value to show the net or gross area for each floor. We have to create a work around with a different schedule with filters for each use and then another one to show the net and gross areas. Additionally if there is a floor that does not have a particular use on it we need to create a dummy area on that floor so that the rows line up in the schedule, and then filter our the 0 area objects.
It is an error prone and cumbersome method to achieve something that should be easy as it is in other programs.
An example is attached of the intended formatting that we can easily achieve using other programs.
1 Comment
fkhan99KQN
This needs more attention. Trying to find creative workarounds to display data properly is not a great use of design staff's time.
Forma Design Contest
Technology Administrators
