Allow a single instance of a model array
When controlling arrays with parameters it is sometimes convenient to allow the value to drop to a single instance i.e. Shelves in a cupboard.
The workarround (adding If statements, visibility parameters and additional single instances on top of the controlling instance) is clumsy and longwinded.
39 Comments
bosborne
This would be a huge improvement in the family editor. Great Suggestion
jkidder
This would save a lot of time!  There are a lot of instances where this would help.  Even in a family where you doubt it would be an issue I like to put it in, because if placed wrong once it will break.
Thanks to all for the many votes.
Please do also leave a comment on the issue you think it would resolve for you as this helps the dev's get a picture of what is needed.
They don't need you to write the code or tell them how to sort it Smiley Wink, just some brief details of the problem you are trying to solve.
jkidder
To expound on my previous comment in any of my families that have anything arrayed (A line based pendant family to signify the backstroke line in a pool, casework that can have 1 or more drawers, casework that can have 1 or more shelves to name a few) I have to have extra families and parameters to deal with the fact that array's break if set to 1.
Ideal - 1 instance of nested family to be arrayed (a
Parameters needed
  • Array Count (user input or calculated on length as appropriate, controls array)
Actual - 2 instances of nested family, 1 arrayed, 1 not
Parameters required to keep the family from breaking if the value needed is 1
  • Array Count [user input or calculated on length as appropriate]
  • array_count_true=if(Array Count<2, 2, Array Count) [integer that controls array]
  • multi=Array count>1 [y/n controls visibility of arrayed family]
  • single=not(multi) [y/n controls visibility of single instance of family]
To really solve the issue there also needs to be something in place to keep arrays from breaking if a formula sets the count to anything under 2 (including 0 & negative numbers), like hiding visibility if the count is less than one.
dplumb_BWBR
We need not only a value of 1, but 0 needs to be a valid value for Arrays, too.
A Window family is a perfect example.
A three pane window has three panes and two mullions
A double pane window has two panes and one mullion
A single pane window has one pane and no mullions
Currently, that requires:
Two pane families - one for the Array and one for the single instance,
Two mullion families - one for the Array and one for the single instance,
Four visibility parameters - one for the pan Array, one for the single pane. Ditto for the mullion
Two "count" parameters # of panes, # of mullions
Two Length parameters
These could all be cut at least in half if you could have Array counts or 0 or 1
@dplumb_BWBR Excellent point we do definitely need to allow it to be set at 0 as well.
mattendler
0 would make the group members disappear. And 1 would only show the anchor member. The array would still be selectable.
Jacob_United
Hi all,
The title explains it all. I don't know how many families I have made that have unnecessary and annoying visibility parameters set up because I can't use 1 as a value in an array. It really is such a tedious, obsoletable (this really should be a word) step that drives me insane.
I suggest that it be possible for arrays to have the number of objects set to 1. Simple really.
Tags (2)
mattendler
Totally agree. Made a post about this earlier, and I think the value of 0 should be available as well!
harlan_brumm
Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
jason.barish
I wish I could give this 100 upvotes. This is constantly a hassle in making families.
Not a fan of the workarounds for arrays. I'm talking about if (Number < 2, Array = 2, Number). For nested families, you can end up with the warning "There are identical instances in the same place. This will result in double counting in schedules". Sometimes I want the instance to disappear when the array is 0, rather than setting up elaborate visibility parameters.
Please don't tell me that an array of 1 does not make sense. In practice, it happens all the time. Change the name from Array to something else if you must.
Tags (1)
Thanks, I missed that one. Have voted for it. Maybe Autodesk can Archive this.
Having the ability to make an array with 1 instance would be extremely useful in situations where the array instance quantity is set to a parameter. For example: a vanity family with either 1, 2, or 3 sinks as options should be able to be constructed using an array.
Tags (1)
pieter7
I'd love to see an option for 0 as well. We have a round table with chair (driven by an array). 0 Chairs should also be an option. It makes it much less likely that people will brake the family + more intuitive.
Ideally, array of 0 should be allowed, and in a later phase when this idea on parameter limitations is implemented, people that don't want 0 to be an option can limit there parameter to have a lower limit of 1.
Enabling array value of 1 would save time and reduce complexity in almost every array I build for door and window families that have many design options and sizes. It's intuitive that it should function this way. Enabling 0 to make the seed element disappear as well--that would be incredible!
Having 0 (invisible) would be important as well, otherwise we would still have to set up a visibility formula.
@Anonymous this has been "Under Review" for over a year, I understand wheels turn slowly in a company the size of AutoDesk but is it destined to remain "Under Review" forever?
lionel.kai
@Anonymous Patience is definitely required when dealing with Autodesk - there's at least one idea that's been "Under Review" for over TWO years. Smiley Frustrated
Another useful idea related to Arrays inside families (and avoiding ridiculous workarounds): Constraining [elements in] An Array
@lionel.kai perhaps we are all missing the point and we should be excitedly announcing milestones of how long our ideas have been under review Smiley Frustrated
Thanks for that other link, have voted for that as well (for what it is worth), you never know someone 5 generations down the line might benefit...
