Running Autodesk Revit with MS OneDrive
Hi there,
I am in the process of starting up a small architectural business where I will be working on Autodesk Revit particularly. The way Revit works is with a "central model" which is usually located on the server, and then each individual PC has "local models" which are synced regularly to the main central model. This takes place around every 30min or so... The question I have is that will the main central model work if located on OneDrive, and would our local models be able to be synced to a model located on OneDrive...?
A bit confusing I know, but any help or experience in this field would be greatly appreciated.
Thank you in advance.
Wayne
jmigdrexel
Observer
Observer
If you are able to test this, please respond and let us know. We are in an EDU environment, and this would be really helpful for our students that collaborate on Revit projects for class.
danial
not recommended. BIM360 is the offical answer - and depending on your user count, will be the most cost effective. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
ahmed_q
Dear All, still on this topic, has anyone been able to experiment Revit cloud worksharing with MS onedrive/sharepoint.
RSomppi
Nothing has changed AFAIK. You might get it to work but there will eventually be problems.
