06:12 AM
- Mute
- Permalink
- Report
Hi there,
I am in the process of starting up a small architectural business where I will be working on Autodesk Revit particularly. The way Revit works is with a "central model" which is usually located on the server, and then each individual PC has "local models" which are synced regularly to the main central model. This takes place around every 30min or so... The question I have is that will the main central model work if located on OneDrive, and would our local models be able to be synced to a model located on OneDrive...?
A bit confusing I know, but any help or experience in this field would be greatly appreciated.
Thank you in advance.
Wayne
