PUBLISHING ON A360 & CONTROLLING PUBLISHED INFORMATION AS PER PAS:1192 CDE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
I am new to A360 and Team and experimenting with it to determine if we should use it on our current projects along with C4R.
When I PUBLISH a model I can select which VIEWS and SHEETS I want the user to see.
In order for me to have a successful workflow for using A360 as a CDE that conforms to PAS 1192 Collaborative Working I would have expected when they download the model, only the VIEWS/SHEETS I have published would be available in the Revit model so I have control of the published views I want other disciplines/clients/stakeholders to see.
However this does not appear to be the case; whatever views / sheets I select to PUBLISH all views /sheets appear in the model regardless of the settings.
How then can I control what the user sees once the model is downloaded?
Please advise?
Regards
Andrew
