Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
How to make background half dark and half faded
3 REPLIES 3
481 Views, 3 Replies
dear
kindly find the attached image and help me to create the layout as shown in the image.
3 REPLIES 3
dzanta
depending on the background data and how it is created you should be able to select it, right click, override graphics by element, halftone....
(EEJan17...for contest)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
in reply to: dzanta
thank you dear for your feedback.
i am working in document file which only contains links and if i select the wall and override, it override the whole wall while i want the specific , means i want to override graphics of one but the next room walls behave normal as dark lines.
dzanta
by default...if you select the link...everything is selected and you can right click to make all of it halftone.  If you want to choose just certain items in the linked file....use the Tab key and the CTRL key to select multiple entities, then right click to change.
