- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a way to export 2D Floor plans from Revit to DWG format without having the Background Mask turned on? I use Navisworks for clash detection and add dwg floor plans to see grid lines and room names in Navisworks. When I export models from an architect's models I have to first open the exported dwg in AutoCAD and turn off then turn off the background mask. This takes time especially when working on multi level high rises. Is there an easier way to eliminate this step all together? Is there a setting in Revit to eliminate the background mask on text?
