Yes/No Visibility Parameter Formula
G00369758
G00369758
I am trying to control the visibility of a vision panel in an unequal doorset family depending on the width one leaf according to building regulations.
The formula I am trying to use is if(Leaf2Width<450,0,1) and im getting the error 'Inconsistent Units'
What am I doing wrong?
if(Leaf2Width<450,1>2,1<2)
G00369758
That worked, thank you!
'not(Leaf2Width<450)' also works
G00369758
Is it possible to make another yes/no parameter which will override that formula?
override how?  Give me an example.
G00369758
I figured it out, if(Leaf2W<450,1>2,VisionPanelOverride)
It allows me to have multiple types within the family with or without vision panels, if I want vision panels it will only allow them on leafs >450mm wide, if I don't want them I can override that formula and it will allow leafs over 450mm without them.
Mike.FORM
for yes/no parameters, they are setup differently than other types when it comes to 'if' statements.
You only require indicating what you are testing since a yes/no parameter has the true/false outcome built into the parameter type.
This means your formula only needs to be --> "Leaf2Width<450"
If this is true the parameter is checked and if not it is not checked.
