Many apologies if this has already been discussed and/or solved elsewhere, I have looked but can't find anything specifically matching this. I have an interesting problem which for the life of me, I cannot figure out. We have a typical project with an existing Phase, and a Future Phase.
A window demolished in the future phase in-fills correctly, see images below:
Existing Window
Existing Window "Demolished"
However, windows in the future phase "wrap" on the existing phase:
Showing the plasterboard and dab retruning to the future window...
Any tips or advice to resolve this, (probably simple), issue would be most appreciated!
Many thanks,
Ash
Solved by ToanDN. Go to Solution.
Solved by atuckerHAEUV. Go to Solution.
Use a different window family without the wall closure ref planes. Or, add a parameter to move the wall closure ref planes to align with the wall surfaces when a box Existing is checked.
To anyone tracking this topic, I've managed to perform a workaround by demolishing the entire wall and creating a new wall on "Phase 2" with the windows etc in. I don't particularly like the solution as it's a bit of fudgery, but it gets the result I'm after.
Any further suggestions, feel free to add! 🙂
Thank you all!
Ash
You can demolish the portion of wall a little wider than the window, then place the window in the infill wall so that you will have wrap in new phase but no wrap in existing.
