Roof Overhang Connecting to Roof below
17 REPLIES 17
Message 1 of 18
dylanc619
668 Views, 17 Replies
I have a problem where i want a eave overhang, i have connected the walls to roof but its picking up the overhang bit in the walls as well,
@ToanDN @constantin.stroescu
17 REPLIES 17
Message 2 of 18
in reply to: dylanc619
Not quite sure I understand the problem, but it sounds like you are having an issue with Attach Top of Wall to Roof.  If this is the case, then instead of using Roof as Attach target, use a Ref. Plane as Attach Target.
...in other works, go to Elevation View of the Gable Side of the Roof, and draw Ref. Planes at the underside of the Roof and Attach your Walls to these RPs.
NOTE: If you use this method with a Gable Wall, you need to split the Gable Wall down the middle and Attach each side independently.
Message 3 of 18
dylanc619
in reply to: barthbradley
No so first i attached the wall to the roof and i just want a little overhang on the outside without the wall connecting to it. I dont want the bit in red connecting
Message 4 of 18
Huh? Are you saying the wall is too long - that it shouldn't protrude? If so, then align and lock the end of the Walls to the Wall perpendicular to it.
...you wouldn't even need to lock it.  Enable auto join and walls will join.
Message 5 of 18
dylanc619
Sorry yeah thats what i mean i dont want to protruding out, i cant align the wall because its locked to the shape of the roof and wont let me align it once the wall is connected with the roof.
Message 6 of 18
You have some constraint in place then.  Press Reveal Constraints to find it -- or just Detach Wall, reposition it, and Attach Top again.
...or just post the file so we can troubleshoot without guess work.
Message 7 of 18
linkboy
In plan sketch edit mode, you can lock the roof overhung to the wall or move the overhung sketch to wherever you want.
Message 8 of 18
dylanc619
The constraint is the roof cause im attaching the wall to it, Sorry im not explaining very well,
I built wall as one maybe i should of built walls on top of each other??
In this picture is how i built the wall as one then im just attaching wall to roof
Then When i attach it attaches to my over hang aswell because it is one wall, i don't want the bit in red i just want the little over hang with no wall under.
This is what i want in red, i had to build a wall on top of the other one to make this happen but don't want to do that i just want one wall.
Message 9 of 18
Out of curiosity, when you edit the Roof and select a sketch line segment, is "Overhang" available or grayed out?
If it is available and not grayed out, then you created the Roof by using the Pick Walls Method.  That's where the constraint is coming from.
Message 10 of 18
dylanc619
Yeah overhang is available i have a over hang of 250mm on it
Message 11 of 18
Okay then, why don't you adjust the overhang there in sketch mode - not by moving walls? Or simply not sketch roof boundary using Pick Walls method?  Sounds like that constraint is hamstringing you.
Message 12 of 18
dylanc619
Yeah i have tried both ways and no luck, yeah its the constraint of the attached walls that is getting me,
I have fixed it with a wall opening but would prefer another way to fix it
Message 13 of 18
Do you want the full height + the parapet = one wall?
If so, make the overhang piece a different roof and join it to the main roof.  That way your wall only attaches to the extent of the main roof.
With that said, I would model the parapet as a separate wall type because both side of the walls need to have exterior material versus the full height wall that have one exterior and one interior.
Message 14 of 18
Like I offered above, you are more welcome to post the RVT here.  Frankly, I'm still unclear what the issue is that you are describing.
Message 15 of 18
SPLIT THE WALL and disable Auto Join (Disallow Join) between the two walls. Use Join Geometry to remove visible linework between the two Wall instead.
Message 16 of 18
dylanc619
in reply to: ToanDN
Yeap that will work, Thanks for that
Message 17 of 18
dylanc619
I got that sorted, but thanks for your help👍
Message 18 of 18
linkboy
in reply to: ToanDN
This works. add Fascia on the gable side with extension off the main roof.  I believe this is the actual construction you expect to see in field.
