Window in future Phase wraps on Existing Phase
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
atuckerHAEUV
327 Aufrufe, 4 Antworten
Many apologies if this has already been discussed and/or solved elsewhere, I have looked but can't find anything specifically matching this. I have an interesting problem which for the life of me, I cannot figure out. We have a typical project with an existing Phase, and a Future Phase.
A window demolished in the future phase in-fills correctly, see images below:
Existing Window
Existing Window "Demolished"
However, windows in the future phase "wrap" on the existing phase:
Showing the plasterboard and dab retruning to the future window...
Any tips or advice to resolve this, (probably simple), issue would be most appreciated!
Many thanks,
Ash
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: atuckerHAEUV
Use a different window family without the wall closure ref planes. Or, add a parameter to move the wall closure ref planes to align with the wall surfaces when a box Existing is checked.
Nachricht 3 von 5
atuckerHAEUV
als Antwort auf: ToanDN
Hi ToanDN,
Thanks for the reply! Unfortunately, your suggestion doesn't work. We still require the window lining to wrap back to the window in the "Future" phase. I was just intrigued as to whether there was a hidden setting or something, but after much digging, I'm stuck!... Strange that the "demolished" opening works, but the future opening behaves like this?
Thank you again,
Ash
Nachricht 4 von 5
atuckerHAEUV
To anyone tracking this topic, I've managed to perform a workaround by demolishing the entire wall and creating a new wall on "Phase 2" with the windows etc in. I don't particularly like the solution as it's a bit of fudgery, but it gets the result I'm after.
Any further suggestions, feel free to add! :leicht_lächelndes_Gesicht:
Thank you all!
Ash
Nachricht 5 von 5
You can demolish the portion of wall a little wider than the window, then place the window in the infill wall so that you will have wrap in new phase but no wrap in existing.
