window frame/mullions schedulle
14 REPLIES 14
Message 1 of 15
tdpalmeida
643 Views, 14 Replies
tdpalmeida
Hello
I'm currently doing a partition familly and i'm having trouble with the schedulles.
So i was doing the familly as a window and i cant see their dimmensions in the schedulle.
The window familly is made with mullions and each mullion as lenght but in the end i can't make them show up and be in the schedulle.
I don't know what i'm doing wrong.
Or if i should skip this and use a courtain wall.
Any ideas?
Hello
Any ideas?
14 REPLIES 14
Message 2 of 15
in reply to: tdpalmeida
There are no values for Height and Width as you show.  What do you expect?
Message 3 of 15
tdpalmeida
in reply to: ToanDN
tdpalmeida
when i use the height in the formula it restrains the mullion and when i had it in whe window familly it doesn't work.
So i'm using the lenght and when i add the mullion to the familly i say that the lenght is the height
Message 4 of 15
If you want to schedule Length then make it a Shared parameter.
If you want Height to the same as Length and schedule Height then add a formula to Height formula box in the family: =Length
Message 5 of 15
tdpalmeida
in reply to: ToanDN
tdpalmeida
Sending the familly
Sending the familly
Message 6 of 15
@tdpalmeida wrote:
Sending the familly
Can you post the Project too?
@tdpalmeida wrote:
Sending the familly
Message 7 of 15
tdpalmeida
in reply to: barthbradley
tdpalmeida
Hello
Yes i can, this is just a test file
Hello
Message 8 of 15
In order to report the "LENGHT" Parameter Value of the Shared Nested Family in your Project Schedule, the Parameter must be a SHARED PARAMETER.
....OR, the "LENGTH" Parameter in the Nested Family must be ASSOCIATED to a Shared or In-Built Parameter in the Parent/Host Family.
Message 9 of 15
tdpalmeida
tdpalmeida
Thanks, this solves the problem.
Tried everything but that.
Message 10 of 15
Message 11 of 15
tdpalmeida
in reply to: ToanDN
tdpalmeida
Sorry i jumped this post.
You gave the solution in the beginning but for some reason i understood that i had to send the family.
Sorry for this and thanks again for the solution, its working fine right now
Message 12 of 15
All good my friend.
All good my friend.
Message 13 of 15
tdpalmeida
tdpalmeida
Good morning.
Dunno if it's better to open another topic or if i can still ask here but.
I changed the mulions to be cut by voids, but when i load them to the window and use a void they are not cut.
The idea is to make a 45º cut in the window that can be turned on and of.
Any idea how i can do it?
Good morning.
Message 14 of 15
RDAOU
RDAOU
@tdpalmeida
It is irrelevant to the parent topic, so a new thread/post would have been more suitable. but since you have asked the question already, it might as well be answered here.
If the mullions are nested components, you should use 1 of the following:
  1. Either a nested Face based void if you intend to cut them in the window family
  2. Pre-Cut the mullions before nesting ... ie: instead of cutting in the window family, cut with a void in the Mullion family
The cut with void when loaded is intended for cutting once loaded into the project/model
@tdpalmeida
Message 15 of 15
tdpalmeida
in reply to: RDAOU
tdpalmeida
Thanks it worked.
I will take remember this next time i need to ask something.
Thanks it worked.
