Need help with parameter syntax
FacebookGroupMember
FacebookGroupMember
Need help with parameter syntax. two issues
1. Visibility parameter: I want element visible if length is greater than X and less than Y. Visibility formulas is essentially A1. 3 (or more) options. If A is visible then both B and C are not visible. Formula should be essentially If A, (not B, Not C, Not D...) but again, that's not the proper syntax
Thanks in advance
kadmonkee
try this link
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/f...
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
AGGilliam
The link above should have all you need, but I love sharing this link because it has so many good examples for formulas.
