Window Frame - Can't Sweep Profile
I have created a profile for my window family but I seem to be unable to create a sweep from it. I am simply told that the profile contains no loops. Am I not allowed to have two loops in the same profile perhaps? I did try deleting one but I had the same issue.
I've tried trimming all corners, checking for overlapping lines etc...
File attached.
Many thanks
ennujozlagam
try this profile attached and see if helps .thanks
Thanks, that works now. What did you do to make it work?
Cheers
ennujozlagam
oopss sorry take this profile forgot to remove the guide ignore the first one. thanks
ennujozlagam
just recreated a new one. it could be some issues in your profile. thanks
Martijn.Pater
Probably you had some lines not meeting properly at a corner, trimming those to meet would resolve the issue (check the loop sketch)...
