Window Family Question
6 REPLIES 6
420 Views, 6 Replies
I'm fairly new to revit. and have a got a test in revit .
I am facing problem with the window openings. How do i bring the window closer to the interior wall ? without flipping the openings ?
i have tried editing the family , but it getting complicated and giving me errors.
The autocad screenshot is how i want it to look like.
6 REPLIES 6
RDAOU
@Anonymous
It depends on the family...in some window families a parameter Inset is added so that you can give it an offset from the outside Finish layer ... See below (an example from an OOTB Revit Library window)
If the parameter is not there, you will need to edit the family, modify it or remodel it to have that instance parameter  Inset which u can adjust from the project
Alfredo_Medina
In the project, select the window > Edit Type > Change the value of the Window Inset property. This will change all the windows of this type. If you need different values of window inset then duplicate the type first, then change the window inset property.
Edit: (I did not mean to repeat the same answer posted above. It's just that I didn't see that answer when I started typing).
Right infront of me 😅
Thanks you so much again dr.rd
RDAOU
@Anonymous
U're welcome? Anything else u need help with on that exame?
Actually yes,
is there a way to show that rounding on a section in revit ?
RDAOU
@Anonymous
You certainly can. Several ways to model such elements...below is an example of a sweep with a nested detail component.
