Why the lights are off when I open the Revit project in a different computer?
適用対象外
475件の閲覧回数
5件の返信
メッセージ1/6
適用対象外
Dear everyone,
The problem I have is that all the lighting are off when I open the Revit project in a different computer.
There is something I've checked:
- Rendering setting: Interior: Sun and Artificial
- Artificial Lights: All "1" (means they are all "on")
- Lighting Family > Edit Type:
  • Photometric > Initial Intensity: 1380 lm
  • Other > Light ON(default): checked
There are five kinds of lights, and they are all OFF.
Now I don't have any clue why they don't light up.
Please let me know if you have any idea or experience to share 🙂
Thank you so much for your time in advance.
Sincerely,
Ann
0 件のいいね
解決済み
476件の閲覧回数
5件の返信
返信 (5)
メッセージ2/6
Well, lets start with the category. Is it turned on?
メッセージ3/6
適用対象外
Hi barthbradley,
Yes.
I checked the "Model Categories > Lighting Fixtures" and the sub-categories under it.
They are all ON.
0 件のいいね
メッセージ4/6
Alrighty, scratch that one off this list.  Are you sure they are not rendering?  Do a Render and then jack up the Exposure Value under Adjust Exposure.
0 件のいいね
メッセージ5/6
適用対象外
Hi barthbradley,
I rendered with "Interior: Artificial Light Only", and saw some lights came out from several lighting fixtures.
It's good enough for me. Thank you!
However, it comes another question: the diffuser is dark, and the material of diffuser is still there. (They don't need the image to link with, they are from default material library.)
I may try to attach the luminous material again or just photoshop it after rendering.
Do you have other advice?
Thank you 🙂
Best,
Ann
0 件のいいね
メッセージ6/6
解決済み
... Sounds like they are Rendering but not bright enough. Did you adjust your exposure, as I suggested above? You know you can also try changing your light properties to emit more light.
...Regarding the diffuser: if it's in a Link, then it's material is coming from the Link's Project - not the Host.
...If by "luminous" material, you mean "Self-Illumination" Material; note that this material attribute is not a light source - nor is it affected by light.
