2019  Latest Updates | New Knowledge Network Articles | Revit Architecture
diana.yr
Alumni Alumni
diana.yr
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Revit Architecture?
 Subscribe to receive updates for new Revit Architecture's Knowledge Network articles.
For more updated solutions, also check out the Autodesk Blogs!
Diana Rouge
Social Media Specialist
diana.yr
December 2019
Error-Please-make-sure-that-the-current-project-is-saved-and-the-project-file-is-available-before-ru...
Material-browser-is-very-slow-to-open-in-Revit
The-element-ID-changes-after-shifting-elements-in-Revit
Fabrication-part-connectors-are-grayed-out-and-locked-within-Revit
Group-edit-tool-buttons-missing-or-of-screen-when-editing-a-group-in-Revit
Shadows-turned-on-in-the-project-are-displayed-incorrectly-in-Revit
Can-t-edit-the-element-It-was-deleted-in-the-central-model-when-editing-MEP-elements-in-a-Revit-clou...
Cannot-load-elements-when-clicking-on-the-BIM-360-Icon-in-Revit
Flux-Architect-font-shows-up-as-square-boxes
Empty-IFC-file-at-opening-in-Revit
Cannot-insert-weight-of-only-selected-elements-from-Structural-Column-family-to-a-tag-in-Revit
A-and-C-dimensions-are-locked-as-hooks-in-rebar-shape-code-23-in-Revit
Some-beam-instances-don-t-show-up-in-elevation-view-when-setting-to-medium-detail-level-in-Revit
Pipe-tee-takes-on-incorrect-angle-values-when-creating-an-installation-in-Revit
Unable-to-link-specific-models-through-Desktop-Connector-in-Revit
Command-Failure-for-External-Command-error-when-selecting-to-print-fabrication-reports-in-Revit
Establish-an-Internet-Connection-to-Continue-when-launching-Revit-2016
Dimensions-revert-to-single-string-when-adding-suffix-in-Revit
Aligning-reference-planes-to-the-surface-of-an-element-is-not-precise-when-zoomed
Files-no-longer-associate-properly-after-installing-the-Revit-beta-preview-alongside-previous-versio...
Revit-cannot-run-the-external-application-APL-when-trying-to-get-license-for-Point-Layout-in-Revit-2...
Autodesk-Live-doesn-t-work-in-with-Revit-2020
Unable-to-sign-in-to-Autodesk-Account-from-Revit
Elements-are-displaying-incorrectly-and-graphic-overrides-are-not-changing-them-in-some-views-in-Rev...
Revit-LT-model-disappears-when-opened-in-full-version
Project-a-Revit-model-into-Civil-3D-section-profile-views
Error-Failed-to-open-document-when-linking-cloud-model-via-Desktop-Connector-to-a-Revit-model
The-family-is-connected-in-a-network-and-can-no-longer-keep-the-connectivity-when-upgrading-MEP-proj...
Graphic-issues-with-in-place-families-in-Revit
November 2019
Error-1310-Error-writing-to-file-C-programData-Autodesk-AdLM-ASR-RVTLT202000F-EL-Adlm-asr-Verify-tha...
Your-local-file-is-not-compatible-with-the-central-model-when-opening-a-cloud-workshared-model-in-Re...
Daylight-analysis-dialog-box-is-missing-in-Revit
Cannot-print-specific-model-from-Revit
Column-profile-from-Advance-Steel-changes-the-axis-position-when-importing-in-Revit
IFC-files-exported-from-a-specific-drawing-in-Fabrication-CADmep-are-blank-when-linked-in-Revit
Unable-to-Load-Insight-Daylight-Analysis-Results-into-Revit-File
Installation-stalls-for-Revit-2020-Content-Libraries
Wrong-position-and-corrupted-geometry-when-importing-IFC-in-Revit
Advance-Steel-Extension-for-Revit-doesn-t-appear-while-opening-Revit-2020
Error-The-coordinates-of-the-points-in-the-point-cloud-file-s-you-are-trying-to-import-are-larger-th...
Assembly-not-able-to-be-selected-as-a-whole-in-a-specific-Revit-plan-view
How-to-avoid-security-vulnerabilities-from-Microsoft-patches-in-Autodesk-programs
Fabrication-Items-properties-not-available-or-locked-in-Revit
October 2019
Revit-Room-boundaries-are-not-found-correctly
How-to-create-complex-cable-tray-types-in-Revit
Revit-cannot-load-BIM-360-because-the-add-in-that-provides-that-resource-is-not-installed-when-re-li...
Network-Slow-error-appears-Worksharing-Monitor-within-Revit
Linked-Revit-model-does-not-show-cut-pattern-in-section-view-of-the-host-model
Difficulty-selecting-elements-in-a-Revit-model-containing-room-fills
Unable-to-reload-linked-Revit-model-in-BIM-360
Opening-Models-that-Require-an-Upgrade-in-Revit
Viewport-boundary-is-too-large-in-Revit
Cannot-add-hatch-pattern-to-toposurface
Missing-objects-in-dwg-export
Slow-to-delete-annotations-and-elements-in-Revit
eTransmit-fails-on-cloud-worksharing-model-in-Revit-2020
Unexpected-results-of-lighting-analysis-for-LEED-v4-EQ1c7-opt-1-sDA-ASE-performed-using-Insight-plug...
Troubleshooting-Publish-failures-with-Collaboration-for-Revit
0-of-1-selected-models-displays-and-publish-is-grayed-out-when-attempting-to-publish-cloud-models-fr...
How-many-versions-of-Revit-can-be-run-in-Industry-Collection-AEC-license
Error-Failed-to-open-document-at-trying-to-add-links-from-BIM-360-through-Autodesk-Desktop-connector...
Send-to-Revit-creates-IMX-and-JSON-files-that-cannot-be-opened-or-imported-by-Revit
Failed-to-initialize-the-add-in-Classification-Manager-when-starting-Revit-2020
When-opening-CHM-help-files-made-by-Robohelp-Revit-Installer-MSI-opens-too
Revit-error-family-can-t-be-upgraded-and-must-be-deleted-when-upgrading-model
File-contains-data-of-Schema-EnigmaSchema-or-TraceItSchema-in-Revit
Inconsistent-Daylight-Autonomy-sDA-preview-Results-for-Insight-in-Revit-2019
Revit-could-not-load-xxx-dll-error-and-an-error-report-displays-when-launching-Revit
Applying-color-to-a-floor-plan-in-Revit
Fabrication-hangers-do-not-resize-properly-when-placed-on-pipes-in-Revit
There-are-no-models-in-this-project-when-opening-a-model-from-the-Shared-or-Consumed-folder-in-Revit
Save-as-Template-option-grayed-out-in-save-options-for-Revit-cloudworkshared-models-saved-in-BIM-360
How-to-change-orientation-of-an-AutoCAD-hatch-pattern-in-Revit
Revit-could-not-load-C-PROGRAM-FILES-AUTODESK-REVIT-LT-2020-CURTAINGRIDFAMILYUI-DLL-while-trying-to-...
File-menu-disappears-when-clicking-user-interface-after-opening-Revit-model-from-Partner-Hub
How-to-remove-preset-Project-Browser-organization-schemes-from-Revit-project-templates
Pipe-fittings-display-do-not-take-over-the-pipe-display-in-Revit
Revit-Error-An-insert-in-a-design-option-cannot-be-hosted-by-an-element-in-the-main-model
Rise-drop-symbol-disappears-after-placing-additional-pipes-in-Revit
A-linked-Revit-model-is-not-visible-in-preview-mode-in-BIM360-document-management
After-inserting-the-IFC-file-as-a-link-it-is-not-visible-in-Revit
Slow-performance-and-constant-pauses-when-using-any-command-in-Revit
Unable-to-Launch-Revit-2020
Import-detected-no-valid-elements-when-opening-a-model-in-Revit
Different-results-when-running-Insight-analysis-on-the-same-Revit-file-on-different-machines
How-to-get-the-Specify-Workset-prompt-to-appear-each-time-a-cloud-workshared-model-is-opened-within-...
A-database-set-up-for-an-older-version-of-Fabrication-is-not-showing-in-a-later-version-of-Revit
Revit-hangs-at-start-when-Naviate-Addin-is-Installed-in-Revit
No-valid-elements-were-detected-in-model-space-when-importing-CAD-files-to-Revit
September 2019
Free-form-rebar-reinforcement-volume-parameter-is-not-calculated-for-each-rebar-separately-in-Revit
How-to-move-automatically-attached-wall-in-Revit
Steel-Connections-do-not-appear-on-ribbon-in-Revit-2018
DWFs-exported-from-Revit-don-t-contain-selectable-elements
DWFX-files-exported-from-Revit-missing-tag-data
Fabrication-parts-become-invalid-in-the-parts-browser-after-unloading-services-in-Revit
Unable-to-import-Revit-RVT-file-into-Infraworks-2020
We-can-t-find-any-Plant-collaboration-projects-when-using-P-ID-Modeler-in-Revit
Design-options-not-working-in-linked-model-in-Revit
Fabrication-Configuration-is-not-showing-in-Revit
You-are-not-authorized-to-change-this-file-when-using-Revit-Model-Review
Revit-2018-and-2019-Bluebeam-fails-to-plot-to-pdf
Error-You-cannot-install-this-product-on-the-current-operating-system-when-installing-Revit-Revit-LT...
Measure-tool-is-grayed-out-in-Revit
Phase-filters-not-behaving-as-expected
Revit-project-units-display-faulty
No-family-content-displayed-when-clicking-the-Insert-Family-command-in-Revit
Revit-2019-is-not-able-to-check-out-a-network-license
How-to-edit-complex-Wall-join-in-Revit
Changing-the-family-for-a-MEP-fitting-might-cause-unexpected-results-is-displayed-when-bend-is-chang...
HVAC-zone-is-not-properly-filling-and-matching-the-spaces-assigned-in-Revit
Can-t-assign-subcategory-for-revision-cloud-in-Revit
Ribbon-missing-in-Revit-for-specific-user
Uneditable-fabric-sheet-in-specific-2d-view-of-a-Revit-model
Can-t-draw-curved-line-when-creating-plan-region-in-Revit
August 2019
Walls-paintings-finishing-are-not-being-exported-to-Ifc-file-format-from-Revit
Problems-activating-Revit-LT-suite
Unable-to-export-systems-in-different-colors-to-IFC-format-in-Revit
Freezing-Not-Responding-when-using-any-part-in-Revit
How-to-install-Revit-Interoperability-for-Inventor
Phase-Graphic-Overrides-behave-differently-with-System-families-than-with-Components-in-Revit
Error-1321-The-Installer-has-insufficient-privileges-to-modify-the-file-when-installing-Revit-update...
Can-t-create-new-Revit-local-model-after-moving-models-to-a-new-server
Robot-Structural-Analysis-link-missing-from-the-Analyze-tab-in-Revit
Dynamo-button-add-in-not-showing-in-Revit-2018
Waking-up-computer-from-the-night-before-puts-file-in-Viewer-Mode-in-Revit
Code-1328-when-installing-updates-on-Revit
Upgrading-older-Revit-file
Rotation-of-families-is-failed-if-always-vertical-family-setting-is-activated-in-Revit
Unable-to-delete-files-from-Revit-Server
How-to-index-such-revisions-that-are-not-displayed-on-the-sheets-in-Revit
How-to-create-such-pipe-schedules-in-that-only-specific-pipes-are-listed-in-Revit
Cloud-team-project-membership-required-when-communicator-for-Revit-is-launched
Slow-performance-when-opening-or-linking-cloud-workshared-models-in-Revit
Line-Is-Too-Small-on-Screen-when-stretching-a-line-in-Revit
July 2019
Unable-to-access-Navisworks-settings-dialog-box-when-exporting-a-model-to-nwc-format-in-Revit
Install-Desktop-Connector-to-load-the-files-linked-to-this-model-when-opening-a-Revit-model
Room-separation-lines-are-showing-across-multiple-levels-in-a-Revit-project
Issue-An-unrecoverable-error-has-occurred-when-opening-any-template-or-any-project-in-Revit
Slow-performance-when-editing-a-group-used-in-a-project-multiple-times-in-Revit
Click-on-template-after-installing-2015-1-15-update-crashes-out-Revit
Unhandled-exception-has-occurred-in-your-application-dialogue-appears-when-optimizing-a-Revit-model-...
Certain-custom-parameters-don-t-appear-correctly-in-Navisworks-through-IFC-from-Revit
an-unrecoverable-error-has-occurred-and-revit-exe-when-working-in-revit
Workshared-cloud-models-grayed-out-or-not-shown-within-Revit-Home
When-going-to-open-a-Collaboration-for-Revit-model-the-Open-dialog-remains-on-Loading-without-showin...
REVIT-How-to-review-orphaned-elements-from-linked-model
Autodesk-Revit-Insight-360-service-unavailable
Oops-Authorization-has-been-denied-for-this-request-error-in-Insight
Communicator-does-not-show-any-projects-or-users
Collaboration-for-Revit-is-temporarily-out-of-service
Errors-associated-with-missing-Transport-Layer-Security-TLS-updates
Disappearing-holes-in-beams-at-loading-specific-Revit-family-into-project
How-to-modify-a-Multistory-Stair
The-lookup-table-has-an-invalid-column-header-and-can-t-be-imported-when-importing-lookup-tables-for...
Operation-Could-Not-Be-Completed-When-trying-to-open-a-file-from-Revit-Server-2019
How-to-divide-a-Revit-model-to-smaller-links
Is-Revit-IFC-Exporter-2020-available
Error-You-cannot-use-the-option-Collaborate-using-the-cloud-appears-when-trying-to-collaborate-a-mod...
Fabrication-Hanger-Weight-cannot-be-displayed-in-Revit-Schedule
When-having-multiple-projects-opened-at-the-same-time-switching-from-one-view-tab-in-one-project-to-...
RFA-or-IFC-file-have-unexpected-tessellation-patterns-when-imported-into-Revit
Unable-to-open-a-RVT-Revit-file-with-Civil-3D
June 2019
Cannot-create-Aerial-project-from-images-without-GPS-coordinates-in-ReCap-Photo
The-Within-your-network-option-is-not-available-when-clicking-Collaborate-in-Revit
Room-Tag-is-outside-of-its-room-when-placing-rooms-on-a-linked-file-in-Revit
Folders-are-empty-or-missing-files-when-opening-BIM-360-files-with-Revit-LT
Can-t-open-IFC-file-in-Revit
Error-Can-t-edit-the-element-It-s-been-deleted-in-the-central-file-when-opening-cloud-model-in-Revit
Slow-performance-when-saving-project-in-Revit
RPC-objects-slows-down-the-navigation-in-Revit
Where-to-find-additional-building-content-for-Fabrication-products
When-starting-Revit-splash-screen-is-appeared-and-the-program-stuck
Warning-To-publish-surfaces-you-must-log-in-to-Autodesk-Desktop-Connector-and-when-exporting-a-surfa...
Color-Fill-visibility-resets-when-changing-View-Templates-in-a-Revit-view
Error-An-error-occurred-while-communicating-with-the-cloud-worksharing-service-appears-when-opening-...
Error-Licensing-System-Error-22-Failed-to-locate-Adls-when-launching-Revit-Revit-LT-2020
Cannot-create-point-cloud-from-specific-txt-file-in-Revit-2018
Cannot-find-non-initiated-models-to-link-in-cloud-model-in-Revit
Current-Revision-Parameter-not-populating-on-a-Revit-sheet
Wall-not-available-in-Revit-section-view
Error-Revit-Server-Administrator-is-not-installed-on-the-server-you-are-trying-to-access-when-viewin...
Error-An-unknown-error-has-occurred-when-e-transmitting-a-Revit-model
Workshared-cloud-model-grayed-out-on-Revit-home
Arrow-of-stair-path-does-not-display-on-floor-plan-in-Revit
What-does-VERSION-3-0-mean-in-Revit-pattern-file
Available-connection-list-changes-to-English-in-Revit-Chinese-or-other-local-language-version
Green-Building-Studio-analysis-of-a-Revit-model-fails
How-to-divide-a-floor-in-two-parts-in-Revit
Object-styles-assigned-to-structural-framing-sub-categories-ignored-when-a-structural-steel-connecti...
Failed-to-initialize-the-add-in-because-the-assembly-does-not-exist
May 2019
Spot-elevations-reference-a-level-for-measurement-instead-of-the-toposurface-in-Revit
How-to-calculate-the-amount-of-light-that-is-reaching-a-partially-shaded-area-in-Revit
The-Uniformat-assembly-codes-do-not-match-the-current-ASTM-E-1557-standard-in-Revit
Revit-crashes-when-tiling-viewports
Template-upgrading-when-creating-a-new-project-in-Revit
Revit-crashes-when-run-on-non-supported-or-outdated-operating-system
Error-Unsupported-Operating-System-You-cannot-install-this-product-on-the-current-operating-system-w...
Checked-By-field-cannot-be-moved-to-another-group-in-the-properties-in-a-Revit-family-file
Error-This-operation-could-not-be-completed-Please-try-again-when-opening-a-model-on-BIM-360-in-Revi...
Material-color-assigned-to-an-item-in-the-Fabrication-CADmep-library-is-displayed-incorrect-after-lo...
RVT-file-uploaded-to-a-project-on-a-Fusion-Team-Hub-is-stuck-at-Step-2-of-3-Discovering-Viewables
How-to-import-Las-point-clouds-files-in-Revit
Revit-viewer-mode-error-that-will-not-allow-save-or-print
Export-to-DWG-with-modifiers-applied-to-MEP-systems-creates-more-layers-than-required-in-Revit
Dimension-arrow-will-not-flip-when-using-the-arrow-tick-style-in-Revit
Warning-Elements-will-be-deleted-when-moving-objects-via-click-and-drag-method-in-Revit
Hiding-Dwg-layers-in-view-using-Dwg-queries-is-not-working-in-Revit
Error-This-operation-could-not-be-completed-when-syncing-to-Revit-Server
Is-it-possible-to-use-the-Design-Collaboration-Module-tools-on-Revit-models-that-are-linked-using-De...
Import-multi-page-PDF-in-AutoCAD-products
Non-responsive-program-when-streaming-video-from-chrome-web-browser-parallel-to-AutoCAD-products
Selection-via-rectangle-or-lasso-does-not-work-in-AutoCAD-when-the-first-selection-point-is-within-a...
Error-message-The-file-you-have-chosen-cannot-be-used-as-a-block-name-or-is-greater-than-8-character...
AutoCAD-products-fail-to-launch-on-Windows-10
Unrecoverable-error-opening-Collaboration-for-Revit-model
Error-AgileDotNet-The-secured-image-was-created-using-a-trial-version-of-AgileDotNet-and-can-not-run...
Removing-Worksharing-Monitor-desktop-shortcut
Export-to-NWC-is-not-in-the-export-tab-in-Revit
Issue-Video-driver-error-has-occurred-while-opening-a-model-in-Revit
errors-during-synchronization-to-central-model-after-changing-to-custom-family-materials-in-revit
How-to-automatically-link-Structural-connections-bolts-to-a-price-in-Revit-using-Dynamo
Revit-hangs-up-when-opening-a-particular-Revit-model
Cannot-customize-Structural-steel-connection-connected-to-concrete-walls-in-Revit
Will-views-on-sheet-in-the-exported-PDF-be-split-when-uploading-to-BIM-360
Cannot-delete-or-copy-model-using-Revit-Server-Administrator
Error-Failed-to-open-document-when-opening-Revit-model-via-Desktop-Connector
Cannot-use-Create-parts-feature-for-a-shape-edited-floor-in-Revit
Views-not-showing-correct-phase-filter-of-linked-file-for-demolished-elements-in-Revit
How-to-allow-multiple-users-to-work-on-different-parts-of-one-Revit-project-at-the-same-time
Error-You-do-not-have-permission-to-perform-this-action-when-trying-to-open-Revit-cloud-models-from-...
Linked-non-workshared-models-do-not-appear-after-publishing-a-model-in-BIM-360
Error-An-unrecoverable-error-has-occurred-when-opening-Revit-2020-Revit-LT-2020
Setting-up-a-parameter-to-calculate-weight-for-structural-members-in-Revit
Using-Hidden-Line-styles-for-a-cut-wall-in-Revit-shows-a-white-dashed-line-in-plan-view
Install-Warning-Error-applying-patch-to-file-C-Config-msi-xxx-tmp
How-to-cut-an-in-place-wall-extrusion-with-a-void-in-Revit
Material-Takeoff-results-in-double-count-of-families-in-Revit
Posts-visible-on-screen-but-not-printing-in-Revit
Error-Project-failed-to-regenerate-with-the-latest-combination-of-changes-when-opening-a-cloud-works...
Slow-performance-when-selecting-and-editing-dimensions-that-contain-global-parameters-in-Revit
How-to-align-Surface-Pattern-in-Revit-Model
How-to-create-membrane-linetype-for-architectural-details-for-architectural-details-in-Revit
Add-ins-don-t-show-up-after-installing-Revit-2020
How-to-share-materials-appearances-with-other-Revit-users
How-to-load-and-place-a-Structural-Connection-in-a-Revit-model
Save-As-command-locks-up-Revit-and-does-not-save-the-model
Revit-model-appears-as-being-cut-in-the-Autodesk-web-viewer
Elements-and-objects-are-missing-from-specific-Views-or-when-printing-multiple-sheets-in-Revit
Error-You-do-not-have-permission-to-perform-this-action-appears-when-attempting-to-open-and-collabor...
Error-File-not-saved-when-trying-to-save-a-file-from-Revit-2020
Unable-to-open-BIM360-cloud-based-models-with-Revit
Display-issue-of-generic-models-cut-by-voids-in-specific-Revit-file
Annotations-within-a-complex-family-do-not-show-as-expected-when-cut-in-Revit
Cloud-points-imported-into-Revit-are-placed-in-not-correct-position-related-to-survey-point
April 2019
Tutorials-for-Autodesk-Structural-Precast-Extension-for-Revit
Exporting-concrete-column-with-cantilever-from-Revit-into-Advance-Steel-model
How-to-split-pipes-by-levels-while-exporting-a-Revit-model-to-Ifc-format
When-exporting-to-NWC-geometry-from-a-linked-IFC-file-does-not-export-correctly-in-Revit
BIM-360-icon-does-not-appear-in-Revit-2020-File-Open-dialogue-box
How-to-export-a-scenario-so-other-users-could-apply-them-to-their-models-in-Insight
Wall-material-is-set-by-default-when-using-Wall-Split-Face-in-Revit
Using-the-File-Open-dialog-crashes-Revit
Error-Connection-failed-when-creating-using-Steel-Connections-in-Revit
Render-in-Cloud-produces-random-results-with-Revit
How-to-determine-cut-and-fill-volumes-in-Revit
Prerequisites-for-Revit-2020
Floor-levels-not-showing-in-Insight-plugin-drop-down-menu-in-Revit
Some-sheets-appear-zoomed-out-in-Revit
System-requirements-for-Autodesk-Revit-2020-products
Error-Video-driver-error-occurred-and-Revit-crashes
Material-properties-do-not-appear-when-model-is-transferred-from-Revit-to-Robot-Structural-Analysis
Released-Revit-2020-Updates-Add-ins
Error-Could-not-perform-segmentation-command-because-the-element-geometry-is-not-supported-when-spli...
Revit-Exporting-material-textures-to-IFC
Get-Up-to-Speed-Autodesk-Revit-2020
How-to-create-shop-drawing-using-the-Precast-tool-that-display-hidden-lines-as-dashed-lines-in-Revit
Revit-Creating-an-Electrical-Circuit-Schedule-with-a-consolidated-circuit-parameter
How-to-set-up-NAS-environments-to-collaborate-on-Revit-models
Country-specific-structural-steel-sections-families-cannot-be-used-running-any-languages-for-Revit
Error-DBApplication-bb3086be-63bb-44bd-99eb-d584c013cf2f-Startup-failed-appears-when-opening-Revit
Dimensions-spot-elevations-move-by-themselves-in-one-view-after-syncing-in-Revit
Mirror-Stair-in-Model-group-causes-spinning-cursor-in-Revit
Reactions-from-Robot-Structural-Analysis-are-unable-to-be-scheduled-in-Revit
Cloud-model-hangs-on-open-when-resolving-a-link-in-Revit
slow-performance-when-opening-small-locally-saved-revit-files
Family-hosting-to-another-family-instead-of-wall-in-Revit
Copied-Revit-cloud-workshared-files-cannot-be-opened-from-the-BIM-360-icon-in-Revit
Error-An-error-prevented-saving-the-file-in-the-cloud-when-trying-to-save-as-cloud-model-from-Revit
Crash-or-hang-when-dealing-with-large-quantities-and-arrays-of-detail-items-or-syncing-to-central-in...
March 2019
Imported-DWGs-in-linked-Revit-files-are-not-showing-up-in-the-host
Some-Imported-DWG-text-does-not-export-back-to-the-DWG-in-Revit
Crash-at-switchin-to-3D-view-after-importing-any-IFC-files-to-Revit
RVT-How-to-change-the-number-of-backup-files
Exclamation-mark-in-a-yellow-triangle-while-trying-to-open-Revit
Unable-to-install-Revit-2019-on-32-bit-Windows
REVIT-How-to-use-the-IFC-parameter-mapping-table
Shadows-and-sun-move-when-rendering-to-the-cloud-in-Revit
Render-material-images-are-missing-in-a-file-in-Revit
Error-Curtain-grid-based-elements-cannot-be-grouped-when-editing-existing-doors-in-demo-phase-in-Rev...
Error-An-error-occurred-loading-a-configuration-file-Access-to-the-path-is-denied-when-launching-Rev...
How-to-export-an-Advance-Steel-model-to-Revit
How-to-show-a-workset-in-a-linked-model-with-dashed-lines-in-Revit
Cannot-export-any-dwg-file-on-specific-computers-from-Revit
Error-Your-current-session-is-using-more-memory-that-your-computer-can-efficiently-support-when-work...
Floor-plan-view-is-empty-and-unable-to-zoom-when-using-specific-view-templates-in-Revit
Revit-Live-is-missing-materials
Running-Revit-Live-without-internet-connection
Structural-column-moved-when-using-Structural-Connection-Base-Plate-in-Revit
Missed-RME-to-FAB-Add-in-in-Revit
Error-The-field-belongs-to-a-different-entity-or-this-entity-is-invalid-when-using-Design-Master-plu...
Unexpected-insertion-point-of-Revit-family
February 2019
Error: "An unknown error occured while accessing ...\Template\Generic\Default" when using the defaul...
Error: "License unavailable. A license is required to run Autodesk Revit on this computer" launching...
Some object lines not printed from Revit 2018
Error: "Your model needs to be upgraded from Autodesk Revit 2009 or earlier to Autodesk Revit 2018" ...
How to check usernames that have been used in Revit sessions on a machine
BIM 360 files are slow to open in Revit
Syncing causes a crash at Reload Latest section in Revit
Does opening a file with Revit 2018.3 upgrade a model created with an earlier update of Revit 2018?
Changing grip color in Revit User Interface
How is PV Energy Production calculated when using Insight in Revit
Cannot place Fabrication hangers onto ducts or pipes in Revit
Error-The-service-is-experiencing-some-problems-at-trying-to-generate-Energy-Analysis-in-specific-Re...
How-to-modify-schedule-view-template-in-Revit
Door-does-not-cut-a-foundation-wall-in-Revit
Shift-p-doesn-t-work-when-Revit-2018-is-open
Error-Failed-to-initialize-the-add-in-Otis-Typical-Elevator-Creator-in-Revit
Worksharing-issues-when-multiple-users-work-on-a-Revit-workshared-model-with-the-same-username
How-to-avoid-Revit-filling-up-the-hard-drive-with-temp-files
January 2019
3D-view-in-shaded-or-realistic-view-displays-in-wireframe
Scheduling-level-parameters-for-Pipe-Fitting-Schedule-in-Revit
Origin-shifted-after-exporting-Revit-model-to-ifc
Drawing-parts-exploded-and-multiplied-when-using-raster-printing-in-Revit
Error-An-unrecoverable-error-has-occurred-when-printing-with-a-RICOH-printer-in-Revit
Error-Your-Autodesk-360-Account-does-not-have-entitlement-when-launching-Revision-Cloud-Manager-App-...
S2C on cloud project intermittently results in frozen Revit
Cannot reload links or add links from BIM 360 in Revit
RIF file exported from Revit not showing all data after import in Fabrication
How to create rebar aligned to curved surface in Revit
Annotation and text not showing in Revit models
How to create grooves on a structural column surface in Revit
Which software allow to present exports from Revit MEP
Is it possible to perform room area calculation in Revit with window niche
Behavior of Neutral Conductors on 3ph, 4w Primary Feeder to Transformer in Revit
Sheets missing from sheet list in Revit
Some IFC walls lose their attributes after export from and import to Revit
Error: "Requested service not available" when signing into Revit
How to deactivate background processes in Revit which decrease performance
How-to-view-the-IFC-exporter-version-in-Revit
Section-mark-from-linked-Revit-model-is-not-visible-in-main-model
Unable-to-use-cloud-worksharing-in-student-version-of-Revit-for-BIM-360-Team
Error-Error-while-transfer-update-line-support-is-while-updating-Revit-model-from-Robot
Linked-DWG-Coordinates-file-from-Desktop-Connector-failed-to-save-locally-when-syncing-to-central-in...
Revit Server doesn't work when selecting another folder as project during installation
How to connect two different waste water system types in Revit into one pipeline
How to rotate a view in Revit without rotating the detail title
eTransmit fails to package models correctly in Revit
Error: "Initiate Collaboration failed. Check the..." appears when attempting to collaborate in Revit
Error: "Licensing Error System 25" when launching Revit 2016
Structural connection elements exported from Advance Steel not visible in Revit
Error: "The library file is currently locked or missing" when trying to add materials to a Revit lib...
Unable to create trunking in Revit
Jumping elements at zoom, display, transparency and shadow casting issues in Revit
Revit freezes when opening or saving on Microsoft Surface Pro after installing Windows Updates
C4R: is it possible to move the collaboration cache to a different drive?
Is it possible to move the collaboration cache folder of Revit to a different drive?
Unable to copy walls from architectural link using Copy Monitor in Revit
Unable to copy walls from architectural link using copy monitor in Revit
File menu very slow to open in Revit
File menu very slow to open in Revit 2019
Clicking "Select..." when printing to PDF causes Revit to be unresponsive
Error-Can-t-install-2019-1-Revit-update
Windows-folder-organization-for-Revit-projects
Error-You-do-not-have-permission-to-edit-the-element-when-loading-a-Revit-link-in-a-BIM-360-Design-m...
Error-The-following-nested-links-will-not-appear-because-their-Reference-Type-is-set-to-Overlay-when...
Is-there-any-32bit-installer-for-Revit-latest-version
Can two instances of one version of Revit Server be installed on the same server?
IFC link does not appear in Revit floor plan
Published sheets appear in Black and white even though thumbnail is in color on BIM 360
Crash when creating pipes in Revit
Wall infill graphics do not match other views in Revit
Contextual help in Revit does not appear and does not refer to online Revit help
Where to find standard rebar shape Revit families in German content
Error: "Install Failed" when installing Revit or Revit LT Update after reinstalling Revit
Cut patterns of walls missing in a 3D view in Revit
Enabling Piping End Connections to Update from Attached Fittings in Revit 2019.2
How to connect within one system type ducts made from different material
Error: "BIM 360:/// File not found. Please verify the correct file name was given." when opening BIM...
How to prevent Revit from creating backup files in the journal folder
Error: "Error - Cannot be ignored. No auto-route solution was found." while connecting two sloped pi...
Error: "1312. Cannot create the directory 'C:\Program" during installation of Revit
Slow response when switching views in Revit
Wall outline is black instead of being gray in Revit floor plan
What is the best file format to exchange Revit project information?
Error: "You cannot synchronize to central until the model is repaired" message appears when syncing ...
How to modify project units in Revit wall schedule and get to/m3 instead kN/m3
Required hard disk space for Revit cloud worksharing models
Make a local copy of a Revit Cloud Workshare model that does not effect the cloud model in BIM 360
Error: "Autodesk Revit Structure is not run" while transferring model from Robot to Revit
Diana Rouge
Great, thanks a lot.
Thanks for taking the time and sharing all these.
