Why room not enclosed?
l.yong1
Message 1 of 10
l.yong1
Hi there,
Please see attached revit file. Can someone please take a look and let me know why the level 2 room is not enclosed?
Thank you for your assistance. Have a nice day.
Best regards,
Lilian
Accepted solutions (3)
Replies (9)
Message 2 of 10
RDAOU
@l.yong1
You have 2 options:
  1. Either you revisit all the bounding elements (Walls, Curtain walls and floor) and readjust the base offsets properly to stop the bleeding
  2. OR you change the computational Height of level 2
    • Select the Level 2
    • Change offset of the computational height (this way it compensate for any offsets given to the various bounding elements)  - see image below
Note: you also have overlapping rooms. You might want to fix the rooms Limit offset too
Message 3 of 10
l.yong1
Hi RDaou,
I have attached the latest file. Any chance you can solve this for me in my revit file?
I tried what you told me. It did not work.
Thank you so much for your effort and time.
Have a great day.
Message 4 of 10
RDAOU
@l.yong1
No you did not : o) see GIF below ... You did not adjust the computational height as suggested
Apart from the above you also did not address the issues with the bounding elements
  1. Wall profile should be reset and base/top properly constrained (\
    • You do not need to edit the profile of the wall to make openings simply edit their type and make check the box Automatically Embed)
  2. Various error on walls overlapping
You need to do some cleaning
Message 5 of 10
l.yong1
Thank you RDAOU. You are a legend😎
By the way, where  do I find the cleaning and do I need to do it.
I just need to export it as gbXML file. I will only do it if it is absolutely essential.
Have a wonderful day
Message 6 of 10
RDAOU
@l.yong1
It is something one does in general...clear all the errors shown under this list
Message 7 of 10
l.yong1
Thank you. I understand your message but it takes too much time to fix these warnings. Can I skip it?
Message 8 of 10
RDAOU
@l.yong1
It is better to fix them.: however, if you have no time for it and all is functioning as per your expectation, you can postpone it (BUT it is NOT recommended to skip it completely)... later during the project you might have various issues happening due to stacking errors and warnings
Message 9 of 10
l.yong1
I only need this model to calculate energy  efficiency in IES. I don't need it for anything else. It should be ok right.
Thank you for your help today. You are a legend
Message 10 of 10
laxpj3
Community Visitor
Community Visitor
Hi all
I had the same problem..it's very confusing
