Structural columns doesn't show cut pattern if they have less than 121.936 cm height in floor plans
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Daniel_Kkarc
309 Aufrufe, 3 Antworten
The title says everything:strahlendes_Gesicht_mit_lächelnden_Augen:image_2022-03-13_173059.pngimage_2022-03-13_173119.png
WHY LIKE THIS?
(Look the top offset)
Tags (3)
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Daniel_Kkarc
@Daniel_Kkarc
Make sure column property Precut is unchecked otherwise check the View Range Cut Plane offset...if all fails embed a nested detail item
Nachricht 3 von 4
Revit considers 4 foot columns dwarves.  If you want to show the cut pattern for those, make them taller and attach the top to a ref plane at the height you want.
Nachricht 4 von 4
RDAOU
als Antwort auf: ToanDN
Dwarves?! If that was a joke then it is definitely a good one : o) ... try unchecking/unticking the "show family pre-cut in plan view" property of the columns and reloading into the project...
see GIF below
