why rhino file runs slow after I export revit model into rhino?
cmrhm
cmrhm
Hi, I export my revit model into rhino through export command, but when I use rhino to open this file, it runs slow, could anyone know the reason?
Here is my procedure:
export>dwg> in setting, I tried both of polymesh or ACIS solids.
Thanks in advance for your efforts,
mhiserZFHXS
Sounds like a Rhino problem... Not Revit.
I only ever used Rhino in school for schematic designs, and it had performance issues. I really don't understand why people go from Revit back to Rhino. You lose everything BIM related.
Any program will run slower when it needs to process non-native geometry.
