All revit models have same error with selecting a shared parameter file
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
lm4
381 Aufrufe, 9 Antworten
Hi! all my revit 2022 models have the same issue -  when i try to go to Manage - Shared parameters, to chose a file, a get immediately an error message saying that the parameters file was not found. There is no way to change this error, i have tried opening many other models in other revit sessions, even older versions and still the same error. Basically i am unable to add any shared parameters to my models, does anyone know why?
9 ANTWORTEN 9
Nachricht 2 von 10
curtisridenour
als Antwort auf: lm4
Can you create a new one?
Nachricht 3 von 10
curtisridenour
You may want to delete your temporary files and clean out your journal files.
Nachricht 4 von 10
Are you saying that you lost a Shared Parameter Text File?  That's not a Revit problem.  Have you tried using  Windows to search your HD for it?
Nachricht 5 von 10
Where do you keep the shared parameters text file? Can you share it here so we can test whether or the file is corrupted?
Nachricht 6 von 10
lm4
als Antwort auf: curtisridenour
Thank you for the reply, but which temporary files? this is hapening for all my models whether it s revit 2022 or revit 2020, so i am not sure where to start with cleaning up. It just seems like a general glitch for all revit models. This issue started with my revit 2022 model which is shared to BIM360.
just to mention, the shared parameter file got deleted from the source folder BUT the actual issue is that the moment in revit i go to Manage - and i just click shared parameters, i get the error message that the file is not found. I don t even get the option of choosing a separate file from a different location
Nachricht 7 von 10
curtisridenour
Nachricht 8 von 10
lm4
thank you, i have cleaned those folders, restarted PC but the error is still there :enttäuschtes_Gesicht:
Nachricht 9 von 10
lm4
Hi guys, problem solved -  the solution is to find the Revit.ini file in the hidden AppData folder, and edit it where the shared parameter field is. Now everything is back to normal :leicht_lächelndes_Gesicht:
Nachricht 10 von 10
curtisridenour
Strong work finding the solution.
