Why is the "Edit Type" panel of the exterior walls is empty?
2 REPLIES 2
317 Views, 2 Replies
I am having an issue in finding all the parameters of the exterior walls in my project such as the thermal properties for each layer; however, when I go to the "Edit Type" of the wall the panel shows only the construction parameter of the wall and it only shows one layer of the wall.
I know that I can get the thermal properties of each layer from the Manage>Materials, but what I really need to know is the R and U values of the wall layers.
So, how can I get all the layers of the wall in the "Edit Type" panel with its R and U thermal parameters?
Noting that I edited the profile of the walls, is that the reason of my problem?
Thanks in advance!
The attached file is a screenshot of what I am getting when I click on the "edit type" of the wall.
Labels (2)
2 REPLIES 2
martijn_pater
You have a stacked wall there. When you click edit structure you will see the configuration of which wall types are being used, those are like sub-walls so to speak. You can also TAB select such a wall inside the stacked wall from a project view directly or edit the wall types in the project (browser). The R value ie. are material properties for the materials assigned to the wall layers of those (sub-)walls.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN....
If you placed the wall already you can also right-click it and Break it up into its sub-walls.
in reply to: martijn_pater
THANK YOU SO MUCH! You saved my life!
Forma Design Contest
Technology Administrators
