Announcements
Section box revit furniture
I want to make a 3D image of my section box. However I was wondering If it is possible to put the furnitures that are downloaded as families in the project, on a thinner line weight/ lighter color?
Besides, I was wondering How it is the best way to render a 3D sectionn box image? I tried to put a amera in the view and than make the eye elevation very high, but it is not really a axonometrix/isometric 3D image...
Thankss
You can't render a 3D Section Box.  Section Boxes are only used to clip the viewable portion of a 3D view. What are you talking about?
...are you perhaps saying that you have a box Furniture Family named "Section" that you would like to show photorealistically?
...you stated that you "tried to put a amera in the view and than make the eye elevation very high".  How high? A lot high or a little high?
Okay so a 'section box' 3D (the half of a building) I can only export as pdf?
I put the camera verryyy high, its like I am a bird flying on top of the building
I wanted to have the half of my building 1. just black white line weight image with the furniture a bit lighter color/lines. So therefore I was wondering if I could change the view graphics of those furnitures.
2. I wanted to 'render' the half of my building with its surroundings..
VG > Models tab > change the Line weight/color/halftone Furniture category (assume that your furniture families are indeed under Furniture category).
There is a plug-in for Revit that will allow you to render your view in Keyshot. This gives you a greater level of rendering control at a much faster and higher quality result than Revit can give you.
You do have to pay for Keyshot but there is a free trial you can try and see how it works.
https://luxion.atlassian.net/wiki/spaces/KP/pages/38552854/Revit
This will also preserve the view including a cropped 3D view.
