Hello
I added some project parameters and set them as instance parameters, and on almost all they are shown as instance, but I have some elements where they are showing as type parameters and it is making more difficult to me adding values on a massive way for this difference.
I have other parameters introduced the same way that are showing correctly in all the elements.
Thank you for your help
Solved by mhiserZFHXS. Go to Solution.
Was the parameter already added to those families within the family editor?
Are ALL the 10_03_OPS Handbook Shared Parameters pulled from the exact same Shared Parameter Text File? How many 10_03_OPS Handbook Parameters are shown under Project Parameters?
Im working on a model previusly worked, so Im not sure, but if I open the family that is having this problem, the parameter i not shown
Sorry, you are totally right, the family have the parameters inside
To set them only as project parameters I have to delete them on the family right?
Or you could just change them to instance parameters in the family. Its up to you.
