Contains an incorrect schema
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
15736 Aufrufe, 4 Antworten
I am trying to open my revit file to finish a project that is due Monday and it is saying it contains an incorrect schema. I am wondering how I fix this issue to open my revit file or I am wondering if it is gone?
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: Anonymous
I run into issue before. I assume you are working with worksharing model. This means your C:\Users\<your name>\Documents folder reach the 20-40gig limit profile limit set by your IT. You may want to get rid of the old Revit project and the temporary folder. You will run into this from time to time. So it is best you change your local file path to avoid this issue from happening in the future.
Nachricht 3 von 5
ennujozlagam
you can also refer to this AKN article and see if helps. thanks
Nachricht 4 von 5
drmarques
I had this same problem today and managed to syncronize by unchecking "Save Local File before and after synchronizing with central".
Nachricht 5 von 5
bihnerbr
als Antwort auf: drmarques
Unchecking the "Save Local File..." just worked for me!  Save some agony!  Thanks @drmarques !
