Why if I have an instance project parameter on some elements is showing as type?
8 REPLIES 8
Message 1 of 9
dmendozaSJ4JV
457 Views, 8 Replies
Hello
I added some project parameters and set them as instance parameters, and on almost all they are shown as instance, but I have some elements where they are showing as type parameters and it is making more difficult to me adding values on a massive way for this difference.
I have other parameters introduced the same way that are showing correctly in all the elements.
Thank you for your help
8 REPLIES 8
Message 2 of 9
mhiserZFHXS
in reply to: dmendozaSJ4JV
Was the parameter already added to those families within the family editor?
Message 3 of 9
Are ALL the 10_03_OPS Handbook Shared Parameters pulled from the exact same Shared Parameter Text File? How many 10_03_OPS Handbook Parameters are shown under Project Parameters?
Message 4 of 9
It is the only one
Message 5 of 9
dmendozaSJ4JV
in reply to: mhiserZFHXS
Im working on a model previusly worked, so Im not sure, but if I open the family that is having this problem, the parameter i not shown
Message 6 of 9
mhiserZFHXS
Expand the Identity Data category.
Message 7 of 9
dmendozaSJ4JV
Sorry, you are totally right, the family have the parameters inside
To set them only as project parameters I have to delete them on the family right?
Message 8 of 9
mhiserZFHXS
Or you could just change them to instance parameters in the family. Its up to you.
Message 9 of 9
dmendozaSJ4JV
Thank you very much!
Forma Design Contest
