Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
why i see weak section mark? its barley noticeable when i print to paper
jkp123
Message 1 of 13
jkp123
hey,
see picture , any help would be appreciate ,
would like to see the section mark with clear Blue like always.
thx in advance
Replies (12)
Message 2 of 13
martijn_pater
Perhaps check in VG/template if section annotation is set to halftone.
Message 3 of 13
Message 4 of 13
jkp123
no ... actually its fine ( halftone not activated )
Message 5 of 13
Do you have two views on the sheet? The sections maybe in the other view.
Message 6 of 13
jkp123
the first picture isnt from a sheet ,
i do have 2 views on a sheet but i dont show sections in one of them at all
Message 7 of 13
If you deactivate the view, are tge sections still halftoned?
Message 8 of 13
jkp123
i dont know how i deactivate the view , but i did remove one of the view ( the one without the section marks),
section marks still halftone 😔
Message 9 of 13
RobDraw
Are the section marks in a linked model?
Share the model to eliminate all the guessing.
Rob
Message 10 of 13
kadmonkee
it may be due to the Discipline assigned to the section tag being different to the discipline assigned to the view
select the section tag, confirm the discipline is correct in matching the discipline of the view you see it in.
when I change my discipline to Structural my section tag disappears by deign of our View templates
check your Phasing also
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 11 of 13
s.borello
I would adjust this under object styles... increase your line-weight for sections to something that will look better when you plot, I have mine set to 4 or 5 I think.  Verify under VG that you don't have any overrides for the section category in your views.
Message 12 of 13
jkp123
it something related to the view template ...
i deactivate the it and then chose the view template again and it was fixed
thx for the help
Message 13 of 13
You don't know what Template Setting was making the Section Marks look halftone?  I would be curious to know.  Can you post the file with that Template?
