Why does Revit name my views with "Floor Plan:" automatically before my own chosen view name?
5 REPLIES 5
louise_carnefjordAV53N
403 Views, 5 Replies
Hi!
Got a question regarding the naming of views. Revit automatically names the views with what it is containing. It hasn't done that before and I don't want it to do that. Is there som setting for this? When I try to rename my views the only thing I can change is my own chosen name, for example "PLAN 1, ENTRÉPLAN, HALL 1". And I don't want the view to be named "Floor Plan: PLAN 1, ENTRÉPLAN, HALL 1". It gets kind of confusing looking att the view list. See attached file.
Thank you!
5 REPLIES 5
you should change your Browser Organization Properties:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-FC5A8E35-BAC5-45AD-B6C2-B6B551417CF9
Hi, thank you for your answer. I've tried to do that, but in the settings there isn't anything I can change to make the name go away. I still want to use the browser organization, just don't want the name to pop in.
Change the group by to "Family".
Cheers,
Edwin Prakoso
Thank you!! That worked 🙂
@louise_carnefjordAV53N wrote:
Hi!
Thank you!
Almost sounds like your Revit INI file setting for SuppressConfirmPlanViewRename has been changed.  I've been there before.  Easy fix.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-0B67F556-4772-4DEC-B465-68C90843FBA4
