AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Why is my elevation bug triangle missing when I reference a drafting view?
7 ANTWORTEN 7
Nachricht 1 von 8
805 Aufrufe, 7 Antworten
I have drafting views placed on a sheet that have images (jpegs) on them. I am trying to place an elevation bug on the demo plan and reference that drafting image on a sheet but the triangle on the bug disappears as soon I select the drafting views. If I select a a drafting view on another sheet it is fine, you can see  the elevation bug triangle. I have looked in the properties, and in edit type, which seems to be eh same as the other drafting views that then triangle shows on. I have also checked to see if it is hidden and the phases in visibility graphics. This is so annoying, please help!
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
What's an "elevation bug triangle"?
Nachricht 3 von 8
als Antwort auf: barthbradley
See how the triangle on the elevation bug is missing compared to the other one I have highlighted in the attached image?
Nachricht 4 von 8
Go to the Elevation and uncheck or resize Crop View
...what a minute: "Drafting View"???  Don't you mean "Elevation View"? I'm a little confused by your workflow.
Nachricht 5 von 8
Try to create a blank elevation view and place the image there. Then reference that elevation view.
Nachricht 6 von 8
@Anonymous: Sorry. I get it now. Cup of coffee helped. Ha!  Unfortunately, I can't replicate your issue.  If you want to post the file with image, we can have a look at it.
...do you get this dialog box when you try to check the box?
Nachricht 7 von 8
RobDraw
Does the view that you are referencing still exist?
Rob
Nachricht 8 von 8
lmitroL9J69
als Antwort auf: RobDraw
I'm having this same problem now.... see screenshot. view exists still, triangle is checked, but it's not showing up anywhere. all other views are fine. can't select the triangle at all can just check and uncheck it, always asks for the view to reference but the grey triangle will not show uppppppp!!
In Foren verƶffentlichen
