Where is Files-Backup ? I cannot find it in Revit 2011.
loboarch
Files are backed up in the same directory as the RVT file exists in.  They will get automatically created witht eh following naming convention. <filename>.000X.rvt.  The ".000x" will be a number that is sequenced as the file is saved.  by default Revit will save 3 old versions and then delet the oldest and add to the sequence.  So you will always have 3 versions back of your file.
If you are working with a file that has worksharing enabled the system is a bit different.  In this case the backup will be a folder named "backup" in the same location the central file exists.  To restore the central file to a previous position you must open it up and then do a rool back function.  Revit will use the files contained in the "backup" folder to restore the file to the point you specify.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
That makes sense but where is the Roll Back Function located.
loboarch
You can find more infomration in the help files.
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS46b90c3cb2c58cad1c1ea29fc7fa3c77a-7fda.htm
Jeff Hanson
Revit Help |
