Where are my shared parameters stored?
marieHPAJL
marieHPAJL
I am quite new to Revit Lt.
A while ago I made a number of shared parameters for lighting fixtures.
I then bought a new pc, had the old one's contents transferred to the new one, downloaded Revit Lt again, and have used Revit Lt since on the new pc.
Now, when I want to make a new shared parameter or use one of those I previously made, I can't find the latter and Revit does not suggest a file for saving my parameter file other than "Downloads"...
I have searched for my old parameter files, but am not able to find them.
So - does anyone know about this kind of problem?
constantin.stroescu
I suggest to do as follows:
  • in your Project file click on the Family that contain a Shared Parameter.
  • In Family Editor , click on a dimension that has Shared Parameter >Label Dimension>Create Parameter
  • then :Parameter Properties>Shared Parameters>>Select>Shared Parameters
  • Edit Shared Parameters > Browse> the Location of Shared parameters (I hope) will open
Constantin Stroescu
Thank you so much for this detailed explanation sir.
marieHPAJL
Thank you very much!
