stairs help
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
racci81
582 Aufrufe, 6 Antworten
stairs help
hey ppls... need a little help with stairs sketch...
I need to get stairs on the end to run in a circle but the sketch is giving me just "Invalid sketch, can't create run by this sketch." when I try to finish and I can't figure it out... I'm alson not sure where I define levels on which to connect on sketch.... here is a screen shot of the sketch and properties  so if you can help I would be grateful and thx in advance.
6 ANTWORTEN 6
Nachricht 2 von 7
constantin.stroescu
als Antwort auf: racci81
Stop the Sketch Boundary like this:
Constantin Stroescu
Nachricht 3 von 7
racci81
als Antwort auf: constantin.stroescu
ty... well I don't get that the sketch is invalid now but this...
thank you for your time
Nachricht 4 von 7
martijn_pater
Try a search for recent topic posts, the exact same question was answered recently.
Nachricht 5 von 7
martijn_pater
als Antwort auf: martijn_pater
Nachricht 6 von 7
ennujozlagam
Try to remove the green line colour in your left side and change riser line and see if helps. Thanks
Nachricht 7 von 7
racci81
tyvm... it was the type of stairs that bugged me... works fine now and I learned something :Gesicht_mit_Zunge: and @constantin.stroescu yes, I switched the border lines, you are right.... ty ty
ty both for your time and effort... I appreciate it
