When selecting a view template and clicking "ok", it goes back to "<None>" without any changes to the view.
Under "Assign View Template" menu box, I select the applicable view template then click ok.  But Revit just reverts back to <None> and doesn't assign a view template. It does this for all views. Can anyone advise??
Thank you in advance!
ennujozlagam
you can try to refer to this ARTICLE and see if helps. thanks
hmunsell
does it stay if you change it in property's of the view? that is where I usually set it....
Howard Munsell
RobDraw
If this is the button you are using, it only works for new views. Existing views won't change with this setting.
Rob
