Based on your instructions this should work but it does not. I cannot export Revit to AutoCad Architecture even by editing the .ini file.
Can you give me a solution that works please? Thank you!
try to repair the program and install latest updates from autodesk and if helps. thanks
If you want AutoCAD Architecture to read the Revit wall, column, door, window and other elements; you need export it out as IFC. After that in AutoCAD Architecture, you have to import IFC.
Editing the ini file for is in to modify exporting to AutoCAD DWG. You need to export from revit to IFC and import the IFC in AutoCAD Architecture.
2022 One year after same problem. ExportACADObjects=1 REVIT 2021 No working at all. Try 2022?
