Hello
Does someone know if it is possible to insert a small size picture into a revit family? I am not asking into a in a revit project
When I try to insert as an image I keep getting the message: "the imported family will not be visible in the project. To improve performance delete the image before saving the family."
I have tried with a smaller size picture
you can refer to this previous thread and see if helps. thanks
Hi , this is a good question and thanks to share it, i try to see if we can import image in rfa and it is passible as i saw but revit asks you to delete the image when you finish and want to save the file for beter performance and here a video for my experiment
you could use the image to create a material. then assign the material to the object.
you may need to mess with the image scale and positioning and set the Repeat to None if you only want it once.
Howard Munsell
You can insert the image into generic annotation and use that as a family. Image will not work with detail or model family.
it is still comes as image and comes with seperate files whe you export it to cad.
