What is the best way to get trim moved back to the plywood plane?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When adding windows in a wall, my window trim ends up outside of the finish layers - see below
What would be a good way for the trim to be adjacent to the plywood instead of outside of the finish?
This is stock double hung window with trim from Revit. This particular wall has stud, plywood and finish as a single wall. The window thickness is based on the host wall thickness, what would be a way to make 1/2" less thick?
