What is best technique for linking repeating revit file link to 14 levels
FrankHolidaytoiling
FrankHolidaytoiling
I have a Revit link that is repeated apartment furniture, plumbing fixtures and specialty that doesnt change for 11 levels and would like to link on every level. What is the best technique copy to each level an instance of this rvt file?
Do I simply copy paste per level, with the link being set to Level 0, so that it comes in at the desired levels?
Copy paste aligned to selected levels, then select all levels you want from the list.
